Old 11-02-2011, 02:46 PM   #13 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by JasonG View Post
There is another possibility,
You may have carbon stuck rings.
Pull the spark plugs.
Rotate the engine so no pistons are at TDC
Using a funnel, fill the cylinders with kerosene
Let sit overnight.
Wiggle the crank a bit.
Replace plugs.
Drive for a day or two.
Change oil again.
IMPORTANT: The plugs have to be out when you work the crank. JasonG's post above does have you do it that way but I want to point it out specifically. If you rotate a cylinder that will try to compress air, when it's got liquid in it, you can bend the crank or damage valves. Because you can't compress a liquid, and something has to give.
Also, depending on how much you wiggle the crank, you might have some kerosene come out at you. BTDT.
Coast long and prosper.
The Following User Says Thank You to brucepick For This Useful Post:
JasonG (11-02-2011)
