Old 11-03-2011, 07:31 AM   #5 (permalink)
Hubert Farnsworth
Hubert Farnsworth's Avatar
Planet Express Ship - '94 Geo Prizm LSI
90 day: 36.57 mpg (US)
Originally Posted by jakobnev View Post
Direct injection FTW!
The engine might be turbo converted(or have the CR in creased) by switching the DI part of the fuel system to ethanol tho.
Note: The mileage number is from the Japanese test, the EPA-number is likely to be significantly lower.
Strictly speaking its both port and direct injected using the Toyota D4S dual injection system and will switch back and forth depending on load and speed, but yes it was direct injection (and the addition of 5-8% more air mass inducted at the beginning of the cylinder charge) that allows for higher compression ratios on regular fuel without detonation, pre or post spark auto ignition, etc.
