Old 11-03-2011, 02:48 PM   #20 (permalink)
beatr911
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
The "Ranger" is the Mazda B2300 in my sig (same vehicle, just re-badged and sold by Mazda). It's a 1996 and has the pintle style EV1 injectors. I'm considering the EV14 12 hole injectors from a ~2005 California Ford Focus, the red injectors.
The Focus injectors are a little bigger in flow rate but the ECU should account for that, they run at the same pressure, ohms, etc. The electrical connectors are different but adapters are available. The Focus EV14's are shorter but extenders are available.
4 holers are easy to come by but since I was going to do this I figured I'd go all the way and use the 12 holers. Searching the net has found me only anecdotal evidence that the 12 holers are better. Guess maybe I'll be the guinea pig on this one.
Junkyard prices are about $6 per injector. Since they are cheap, I'd like to find 6 of 'em in case one or two are uneven or damaged.
Good design is simple. Getting there isn't.
