Old 11-04-2011, 01:59 AM   #17 (permalink)
SentraSE-R
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
From a gearing standpoint, MT xB users should look at a differential ring and pinion swap, for the Yaris's 3.25 final drive ratio v. the xB's 4.31. That brings our rpm @ 60 mph down to 2334 from 3096 with the stock tires. The 5th gear swap to .725 from our .82 only drops our 60 mph cruising rpm from 3096 to 2738 with the stock 4.31 differential.
That gearing swap is going to require some major rethinking, as each gear will feel like the one above it used to feel. Second gear will have the shift points that third used to have. Third will be like fourth used to be, etc.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
