Originally Posted by Old Mechanic
Cutting a part of the coil off with a die grinder works great if you want it lower and slightly stiffer. Think of the spring stretched out straight like a torsion bar. AS you make it shorter it gets harder to twist it the same amount.
regards
Mech
This is exactly right!
My own experience with shortening the springs with a torch has all been bad. You change the temper in the metal so badly that the spring is quite likely to break - several of mine did. I found that a cut-off wheel on a small grinder worked best.
