Old 11-04-2011, 03:21 PM   #150 (permalink)
cycleracer88
Yes, when you change your drive belt, you only delete the rotor blades on your new mechanical water pump. After it you can install the electrical water pump. I wanna do the same on my 1.9TDI engine, because my mechanical water pump needs round about 3HP :-O.
No, the intercooler isn't stock. OEM there is a SMIC installed. It is too small for the 130HP engine. So I installed a FMIC. The FMIC is OEM from Seat Iibiza Cupra TDI. It has a good efficiency. But this wanna too big for your 1.2TDI engine.
Do you have pics from your deleted intercooler and pipes?
btw:
You also could install a bigger OEM air intake filter... I install a TTRS/ R32 Filter box on my car, because it has a good air flow.
How much is the weight of your battery?
