Old 11-08-2011, 11:33 PM   #17 (permalink)
oil pan 4
A block heater is the way to go.
The problem is the oil hangs low and is away from the rest of the mass of the engine block. If you heat just the oil and not the block the oil will turn back into honey as soon as it get pumped into the cold block.
When I built my diesel engine I installed two 650w block heaters.
Next gas engine I build will get a block heater from now on too.
125 watts isnt much. Its better than nothing.
Ripping out a freeze plug and putting in a block heater would be the best way to go.
