Thread: 96 Saturn SL1
Old 11-09-2011, 05:08 PM   #60 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by 96SATSL View Post
I did the clear and pizza pan versions, but I decided to take them off as I did not know the actual impact they had on MPG. For the last two days I did not notice a drop once they were removed, so I assume the stock hubcaps arent too bad as they are. I think I'm gonna ditch the wheel covers for now. As far as OEM they were the only thing that looks different. Now they are off with no negative impact to total MPG.
What do you mean about roof trip?
I suspected that you wouldn't see much of any improvement with the wheel covers, but kept that to myself.
By roof trip, I meant a sort of shelf spoiler that would be mounted at the edge of the roofline just above the glass. It would separate the wake more cleanly than having a sudden curve at the rear. The Audi A2 has one at the end of its' roofline. Imagine something similar added at the junction of the roof and rear glass.
Since your roofline is quite short, I'm guessing that you may not see much of an improvement. What you really want is to extend the roofline out along the template cure as far as you can and create a Kammback.
I just mentioned the trip because you wanted to keep the car looking semi stock.
I'll let the experts take over now.
