Thread: 96 Saturn SL1
Old 11-10-2011, 01:31 AM   #62 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
I believe that running a higher octane increases efficiency provided that you boost the compression ratio. If the CP remains the same and the octane rating increases, odds are it won't boost fuel efficiency.
Wisdom dictates that you should use the recommended octane as specfified in your car's owner manual.
