Thanks to the linked posting above, I added some thin rubber feet to the tailgate buffers, the centre console "bridge" and to the exsting rubber buffers behind the upper and lower glovebox doors - much quieter now. The one remaining rattle is from inside the dash behind the steering wheel - I suspect something which should be clipped or insulated inside is loose and not covered.
