Old 11-14-2011, 07:12 AM   #16 (permalink)
HighMPG
HighMPG's Avatar
Super Duty - '12 Ford F250 Super Duty XLT Long Bed Super-Cab
90 day: 15.29 mpg (US)
I got it to work!
I didn't know you had to be on the lifetime section of the FCD, then press "trip" to switch between A and B but it works just fine! I also Filled up the tank again now with a perfectly running car! EGR plate cleaned, EGR replaced, oil change, brand new tires. This next tank should be good! the last tank I mustered 47.7 at 456 miles which is way better then 41.5 and 324 miles. Now everything is fixed, EGR plate cleaned, EGR replaced, all fluids serviced, brand new RE92 tires, and 89 of full tank, the last 2 tanks I used Medium grade gas so we'll see how 89 does.
Name:	Copy of 2011-11-13_18-37-33_714.jpg
ID:	9734   Click image for larger version
Good Bye Insight Hello 6.7 Diesel Truck!
**My First Hybrid Insight**
