Originally Posted by lama
It would be very helpfull if you could give me the length of each side of the diffuser you made(don't know if I explained in right!)!
I also have a mini cooper S and I am looking forward to construct the same diffuser,as well as the front body panel!Any photos you have from the front one,would be helpfull also!
Which side? The underpanel is just a 4x8 sheet of coroplast cut in half and trimmed to fit, it wedges under the side sills and exhaust tunnel heat shield...front lip if folded up under the wheel liner & heat shields (aluminum tape was applied to the edge that comes in contact with the heat shield). The trailing edge is secured with aluminum C channel which also attaches to the front edge of the diffuser...so it becomes 1 piece.
