Old 10-16-2011, 03:15 PM   #91 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
That's good. I'm just concerned because some people have actually melted our stock diffuser after switching to an aftermarket/custom exhaust.
Old 11-12-2011, 01:33 PM   #92 (permalink)
Originally Posted by curv872 View Post
After almost a year on the car its holding up very well. No problems with heat, since the top side is covered with an application of aluminum duct tape.
It would be very helpfull if you could give me the length of each side of the diffuser you made(don't know if I explained in right!)!
I also have a mini cooper S and I am looking forward to construct the same diffuser,as well as the front body panel!Any photos you have from the front one,would be helpfull also!
Old 11-16-2011, 02:59 PM   #93 (permalink)
Which side? The underpanel is just a 4x8 sheet of coroplast cut in half and trimmed to fit, it wedges under the side sills and exhaust tunnel heat shield...front lip if folded up under the wheel liner & heat shields (aluminum tape was applied to the edge that comes in contact with the heat shield). The trailing edge is secured with aluminum C channel which also attaches to the front edge of the diffuser...so it becomes 1 piece.
Old 11-16-2011, 03:57 PM   #94 (permalink)
EcoModding spendthrift
WindedWarrior - '12 Ford Focus SE
90 day: 33.46 mpg (US)
Thanks for posting the rear diffuser howto.. I might add one to my ride as well (not a mini).
"May the wind always be at your back and the sun always upon your face. May the wings of destiny carry you aloft to dance with the stars."
~ Boston George
Old 11-18-2011, 12:53 PM   #95 (permalink)
OurInsight - '06 Honda Insight
Originally Posted by InsightfulRay View Post
Not a big fan of A/B drag tests. Personally, I don't trust short distance A-B-A testing
I agree with you on this score. I am particularly skeptical of A-B-A testing on an Insight 1 on which it is very difficult to keep fuel consumption stable. I have become a fan on moderate length "standardized" test circuit. Mine is about 20 miles one way and fairly flat. I test at least 3 times, averaging both directions.
I was able to get fairly consistent results on a Toyota Echo on which I had added an after market cruise control, but again the course was of moderate length, about 5 miles.
Old 11-18-2011, 01:11 PM   #96 (permalink)
Insight 1 Rear Diffuser
Reposted as thread.
Old 11-19-2011, 07:16 PM   #97 (permalink)
rainagain's Avatar
Peugeot 206 1.9D - '98 Peugeot 206 L
90 day: 44.91 mpg (US)
Originally Posted by johnf36 View Post
side skirts
How are those attached?
Old 02-04-2012, 05:39 AM   #98 (permalink)
what's the book name in your first post about the CD and CLR?
Old 02-06-2012, 02:12 PM   #99 (permalink)
Not sure exactly, but J. Pottoff's work is mentioned in various sources.
2 to check out - "Aerodynamics of Road Vehicles" as well as "Race Car Aerodynamics"
Mentioned here to on pg 10 - aero
Old 02-07-2012, 05:51 PM   #100 (permalink)
lift
From the rear valance, my design extends back 26" to the rear subframe and is nearly 4ft wide. From the subframe, the underpanel begins a gentle rise at the same angle another 12" back. So we are talking about nearly 12 square ft of area acting on the air.
A and B of diagram above, the best angle for drag reduction (CD) is from 2 and 4 degrees.
A (like mine), the best angle for reducing lift (CLR) is 6 degrees.
B, the best angle for reducing lift (CLR) is 11 degrees (at the expense of increased drag)
Made out of black coroplast, total weight with strakes, just over 4lbs.
Visual indication of how far back the 6deg rake goes back to combine with the flat underpanel:
Now for the shocking results!
I drive the same commute to work everyday and usually average about 26-27mpg. After logging 106 miles with the diffuser, I filled it back up with 3.538 gallons....that's now an avg of 29.9mpg!!!
Joe
the Mini,should have a squareback wake,which doesn't produce lift.
2004 MINI Cooper S - Improving Aerodynamics iplaysdrums Aerodynamics 90 08-08-2012 02:13 AM
Drag Racing Aero Help Bennett_Racing Aerodynamics 33 06-28-2010 06:02 AM
rear diffuser fabrio. Aerodynamics 30 05-17-2010 12:36 AM
rear diffuser build thread LeanBurninating Aerodynamics 24 06-06-2009 08:32 PM
