Not to be confused with a Solara, I present my Celaero. Thats a working title.
Thats the mostly front belly pan, thin coroplast with Prius wheel spats (customer came in and actually wanted them removed
This is the partial grill block. No temp change at all with this. Will expand this as time passes.
This little guy is the beginning of covering a huge hole open past the subframe. Coroplast and a VW heatshield.
So this is a preliminary rear deflector. The C-brackets keep the coroplast unbent around the spare tire hump.
Most this stuff was just a quick mockup. I only had to drill one hole to mount all this stuff. Tell me what you think. Where do you see improvement??
Robbie
