Old 11-20-2011, 11:24 AM   #23 (permalink)
user removed
Most here recommend acceleration at 80% of wide open throttle. While it will use more fuel per instant of time, you get to your desired speed much faster than very gradual acceleration. Understand that WOT can be a confusing term. Does it mean you have it floored? Does it men you have no manifold vacuum?
I have found that the best rate of acceleration in any automatic is as fast as you can accelerate without delaying the up shifts in the transmission.
Try accelerating and make a note of the speed at which your transmission shifts into the next higher gear. Gradually increase the throttle position on each of the next accelerations until you get to the point where the transmission stays in the lower gear longer than at lower throttle positions.
Then back off until you have found the "sweet spot" where you are not delaying up shifts but accelerating at the perfect rate, just bellow the shift "hold" point.
That gets you to speed with the least amount of fuel consumed and allows your car to spend more time cruising instead of spending more time accelerating. In watching my cars that have instant fuel economy I saw that the difference in fuel consumption would be fairly small, while the time accelerating could be as much as 50% less. Getting there faster uses less fuel when you consider the time spent at a higher rate of consumption.
regards
Mech
The Following 2 Users Say Thank You to user removed For This Useful Post:
Quiplet (11-20-2011), ShinyMew (06-06-2015)
