Old 11-20-2011, 09:13 PM   #95 (permalink)
BobM
EcoDreamer
If I ever get through pulling wires and get the engine pulled and cleaned maybe I can start this build.
Jack, earlier in this thread you were doing a mock-up of the rear section using 2 inch square tubing and your Geo motor mounts seem to be made for this. I plan to make the lower portion of my frame of 1 1/2 inch like the Midlana, since I am goling to have a Midlana style cage, and was wondering if this would be sufficient for the rear section also. Could your motor mounts be modified to work with this size tubing?
Another question. You have designed front suspension components for a Miata based car. Could I just buy those components and build my front frame to match. As you can see I am not an engineer, or even a "car person". Andrew Moore and I plan to get together and I hope he can keep me straight on this project.
