A while back i started thinking that my temp gauge was staying at the bottom a bit too long and then jumping up to the middle a bit too fast. Knowing that the sensor is at the top of the engine i decided to check the coolant level, and lo and behold it was low. I also noticed that the gasket on the cap had turned itself into crap.
So an actual gauge, even without numbers, isn't useless, if you pay attention.
