Originally Posted by Sykomor
I don't really know the definition of hypermiling. Im trying as good as I can. I was hoping for better but "EPA" or the european equivalent is very high (low in l/100km).
20% over the rated fuel consumption will give you the coveted ecomodder.com hypermiler status.
If you start from the rather unrealistic NEDC numbers, doing 20% better is quite an achievement.
I'm trying to get my hands on a pair of 185/60-15 to se if bigger diameter will improve things.
The wider tyres are very likely going to give more aerodynamic drag.
