I actually suspect the lem. Does the software have the ability to ignore negative current readings from the lem? This caused a cold weather problem with the charger that uses a hass 50 a few weeks back.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
