Old 12-06-2011, 09:54 AM   #25 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by PaleMelanesian View Post
Here's one thought. $681 is a better price and it's still OEM. You have to install, but I think you can handle that.
Honda Automotive Parts
You'll still be missing the HX gear ratios with those swaps. Or, do you already have that VX swap in place?
Yup. That's the HX ECU (ECM/PCM). When searching for a DX one, I get everything but the ECU on the list, seemingly confirming what the local dealer told me. The HX conversion would be more work, and I would have preferred the chance to plan and learn. But maybe this is motivation! My plan re: the gears is to try this substitution of the final drive from a 1992 VX I bought for $58 shipped, with the countershaft. It should slip right into my tranny and actually give me taller gearing than the HX. Then I'll shorten the gearing a little with the VX wheels I have and be about 10% taller than a stock HX with maybe 80lbs less rotational mass and unsprung weight.
So does anyone know if I would need to swap for the full HX air intake manifold or is their a way to add EGR to the existing DX manifold? I am guessing my answer is no.
