Well I think I may have found the issue. I swapped out the atmega328 chip with a spare. It now has a steady GPH reading and iMPG reading. I'm hoping that the chip was just damaged from a previous failure and not because of the injector pulses.
As far as the numbers go thats a non issue. Those numbers came from my Insight and I was playing around with the settings. The Civic owner has put in the correct values for his car and so far its working fine. 58MPG on one of his trips the other day I think he said.
