Old 12-06-2011, 06:23 PM   #19 (permalink)
aerohead
Originally Posted by onefstek View Post
Boat tail idea is no go. I can't extend more than 12" behind the rear of the car.
The subaru scoop is a no go either, its been tried and doesn't work. Its been tried and it slows down the car due to air being limited by the dead area.
Best I could do for it is most likely this :
Stefan
Can you gang all the throttle body inlets into a common inlet plenum and run that into a home made Pro Stock style scoop.These have the lowest drag and are high enough to get up out of the boundary layer.It would probably project a bit ahead of the nose.Is that a rulebook breaker?
