I designed a stand for a bike on the CR-4 Forum, which had two tubes projecting down and out, ( to whatever width you want) with telescoping tubes inside. When you stop, push a button, till they reach the ground. Release the button locks the down tube which are both on the ground and will hold the bike vertical, no matter what angle the "ground" is. Push the button and retrieve the ground tubes with a cable on a lever, which the button is on. You can make it as wide as necessary. You project looks very good!
