ok can i ***** about the weather now? two weeks ago it got cold and i ended up with 56 mpg. Last week it warmed back up and i go back to 60mpg. this week got cold again and now I am back to 56mpg. So it looks like anything below 60 degrees is where he set point is for my drop. I am going to pull the t-stat out and see if its stuck open. because the driving i have done and the amount of grill i got covered it should have moved past 1/4 of the gauge. and the heater does not blow as hot as it should.
