Old 12-02-2011, 07:46 PM   #151 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
sounds like i need to step up my game a little
What, to catch PaleMelanasian? Ty and I are dropping and you are still climbing( I hope you do take the number 1 spot).
I just put the studded snow tires on, and MAN do they drag. I am REALLY going to have to go all out to stay above 100%. I bought them last winter before I came here and heard about the Hakapolita's awesome traction and rolling resistance, and can't see a good reason to get rid of perfectly good( and paid for) tires. When these wear out, however....
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 12-02-2011, 11:58 PM   #152 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
Originally Posted by deathtrain View Post
sounds like i need to step up my game a little. I just got back from geting the stuff for the mpguino. and since im santa I know gauges will be under the tree.
Your gonna like the guino!
Go for it man, the rest of us will just try to stay warm
Old 12-09-2011, 06:57 PM   #153 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
ok can i ***** about the weather now? two weeks ago it got cold and i ended up with 56 mpg. Last week it warmed back up and i go back to 60mpg. this week got cold again and now I am back to 56mpg. So it looks like anything below 60 degrees is where he set point is for my drop. I am going to pull the t-stat out and see if its stuck open. because the driving i have done and the amount of grill i got covered it should have moved past 1/4 of the gauge. and the heater does not blow as hot as it should.
Old 12-09-2011, 07:31 PM   #154 (permalink)
Diesel
Could be the t-stat. To test, I use hot water or warm up the chamber end with a propane torch far enough away to gradually heat it.
Weather is always a factor, my friend. I'm just about to post a 42mpg fill. My snow tires REALLY grip. Re-re-RE learning to drive economically.
Boat tail project
Old 12-09-2011, 09:13 PM   #155 (permalink)
I think its stuck open or does not have one. At the peak of summer I had 50% grill block and it was 105 out side. the needle only got to a little over half way in the temp gauge. Now it got colder and I got about 70% grill covered and the needle never really moves. It's acting like my old truck did when i removed the t-stat. also no need for testing the t-stat is on top and only take two bolts. so it a 5 min job at the most.
Old 12-09-2011, 09:37 PM   #156 (permalink)
Diesel
umm... Yup. Sorry, stuck open would be VERY easy to spot after removal. Typing sober, again. Misread. Better now.
BTW- What's an Ecomodder Elite Club? Is it like a Louisville Slugger?
Boat tail project
Old 12-11-2011, 10:18 PM   #157 (permalink)
oh crap..... old t-stat i would never get out of high idle. now with in minutes I am at temp and in low idle with the temp stable. i found the t-stat was not bad but the rubber o ring around it was gone causing to much blow by. it was bad enough that the engine would nt get to the proper temp. so all and all... unit fixed. i just have to watch my grill block now to make the proper adjustments to the proper t-stat function.
Old 12-13-2011, 06:16 PM   #158 (permalink)
Diesel
Nice find on the t-stat. Did you get the Guino yet?
Boat tail project
Old 12-13-2011, 06:45 PM   #159 (permalink)
yea I am glad I found it too. no the car ACTUALLY gets up to temp. It idles so low i thought i forgot to bump start it once and grinded the starter a little...
Guino yet? I think i got mine around April or so but have never had the time or motivation. I would always get the tools out and have a beer.... then never got away from the beer to do any good. This last week end though the GF grounded me and told me no beer until i get some man work done first so i picked that car to work on... hence the t-stat change. Well I was doing fine on locating the proper wires until i got to the Injector signal. I am getting 12 vdc on both wires and don't know what to do next.
the post is here with my car drawings
http://ecomodder.com/forum/showthrea...elp-19741.html
Old 12-20-2011, 02:53 PM   #160 (permalink)
Smash 100 MPG barrier
mbrac's Avatar
Frankie - '07 Ford Focus SEL
Great Job - my goal is to smash 100 mpg - stricely highway - doing it in an east to west coast trip - hopefully during warm months of 2013 -
again - great work - I'm sure there was allot of BST - blood - sweat - and tears!!
