Old 12-11-2011, 04:49 AM   #5269 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Now the summer is back?! It's friggen freezing over here!
Nice heatsink!
If you go over 5000 Ohms, it just ignores anything beyond it. No biggie. I think about 4500 would be full throttle.
The yellow wire comes disabled. I need to start enabling that sucker. You hook it to the positive of a contactor coil. Make sure you have a diode across the contactor coil to stop the inductive kick from going where it shouldn't. AFter a programmable amount of time, the yellow wire goes from 0v to 12volts. That powers the coil. Program it like this through the serial port:
pc-time XXX
save
Where xxx is a number in tenths of a second. For example:
pc-time 58
save
would cause the controller to wait 5.8 seconds before making the yellow wire go from 0 volts to 12volts. The time you have to wait depends on your precharge resistor value.
You need to wait about 0.1*R seconds, where R is the resistor value. So, if you had a 100 Ohm resistor, you would have to wait 10 seconds.
kits and boards
