Old 12-12-2011, 08:24 PM   #17 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by 3dplane View Post
I have DP40 primer which is an epoxy primer. I tried it on a scrap piece of foam and it ate into it. That's with no thinning just the primer and the hardener mix. Must have other chemicals in it to chew the foam!?
I think he was referring to epoxy resin, if you were to use that over foam. I have read that a coat of latex house paint seals out the solvents in your bondo or other coating.
Looks good! I have a small convex mirror on my folded mirror. It seems to work well in highway use.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
