Sounds like he pulled the fuse for it. I heard to run the defroster while gettin air from the outside rather than recirc from inside and tried it with awesome results. If my AC worked I woulda just cycled it for a minute then went to inside but this works just as well! You wont miss it entirely, but like said above, sometimes there are moments where only runnin the air thru the AC system will totally remove any moisture and keep the windows clear. You could also try to silicone beads in a sock deal that someone posted up on here a while back to help in the mornings etc.
Matt
