Old 12-13-2011, 01:20 PM   #22 (permalink)
NeilBlanchard
I removed the fuse for the A/C; sorry I wasn't clear.
You cannot do this on the Prius; at least the one that has the touch screen controls -- if the A/C fuse is pulled, the *entire* HVAC system is disabled. Grrrr, stupid engineering choices.
As I said before, they should program it to run the A/C only at maximum/full defrost and then only for a minute or two, and then go to heat only. And have a manual override.
