Old 12-13-2011, 01:31 PM   #23 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
I removed the fuse for the A/C; sorry I wasn't clear.
You cannot do this on the Prius; at least the one that has the touch screen controls -- if the A/C fuse is pulled, the *entire* HVAC system is disabled. Grrrr, stupid engineering choices.
As I said before, they should program it to run the A/C only at maximum/full defrost and then only for a minute or two, and then go to heat only. And have a manual override.
Based on my fuse box, I think mine's set up the same way. There are some fuses for "HVAC" but nothing for jus the AC.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
