The alt is connected to the SADS isn't it? If you disconnected the SADS what would drive the alt to provide power to your accessory motor? Or are you talking about mounting a gas-driven motor to the accessories?
If you could mount the alt directly to the engine, you could then convert the radiator fan, power brakes and PS to electric. You could even convert the AC to electric, but it's expensive and difficult.
Brian
