Old 12-13-2011, 09:42 PM   #5295 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Amin, what sort of contactor do you have? Do you know if it has an economizer? Are you powering the control board with an auxiliary battery or a DC-DC? Do you have a diode across the coil of the contactor? Um... I can't think of anything else.
Another fault that I added is if you give it throttle when the contactor is open, when the pwm goes to 100% and the current feedback is zero, it gives a fault. I would check to see if Q1 is bad. If it is, your coil may not have an economizer on it?
kits and boards
