Alright, I think Ive got some insight.
Your controller is triggering 4 different faults, at different times.
The most common one, and worst is hex code 1 binary 00000001. This is a throttle fault code.
There is also codes for Paul's pwm with no feedback fault hex 8 binary 00001000.
The other 2 faults are for high pedal lockout and precharge. codes 10000000 and 00100000 respectively.
The throttle fault is what is causing the trouble. What are you using for a throttle pot?
After looking at the files again, the pot was not connected for some time.
If you look at these lines, you can see the throttle connected, then disconnected and then connected again. The 3rd column, RT, is the signal from the ADC.
Code:
TIME TR RT CR CF HS PW FB BA AH TempF
1009.5 0 717 0 0 153 0 0 0 5 40
1009.6 0 717 0 0 153 0 0 0 5 40
1009.7 0 717 0 0 153 0 0 0 5 40
1009.84 0 717 0 0 153 0 0 0 5 40
1009.92 0 717 0 0 153 0 0 0 5 40
1010.01 0 717 0 0 153 0 0 0 5 40
1010.1 0 716 180 90 153 22 0 4 5 40
1010.2 0 717 0 0 152 0 0 0 5 40
1010.3 511 0 0 0 152 0 1 0 5 40
1010.4 511 0 0 0 152 0 1 0 5 40
1010.5 511 0 0 0 153 0 1 0 5 40
1010.6 511 0 0 0 153 0 1 0 5 40
1010.7 511 0 0 0 153 0 1 0 5 40
1010.8 511 0 0 0 153 0 1 0 5 40
1010.9 0 706 0 0 152 0 1 0 5 40
1011 0 716 0 0 152 0 1 0 5 40
1011.1 0 713 0 0 152 0 1 0 5 40
1011.2 0 715 0 0 153 0 1 0 5 40
I got to go to bed now. gotta get up early. This should give some insight.
-Adam
