Old 12-13-2011, 11:02 PM   #5297 (permalink)
amino
EV DIYer
Hi Paul, I have a KiloVac EV200AAANA contactor with 'economizer attached', so does not need a diode The board is powered by a small auxillary battery which is charged by the DC-DC converter.
Q1 seems okay, but I might try replacing it and the optocoupler U9 as well after I get them from a local electronic component supplier. Any idea what the voltage readings should be at U9 and Q1 before and after precharge?
I have sent Adam the cvs files I saved when I tested the cold controller earlier today.
Amin
