You should DEFINITELY put a diode across the contactor coil. Cathode to +, anode to - and it needs a PIV rating of a couple or more times the supply voltage with a current rating equal to the coil current. If you don't fit a diode, the inductive spike generated when you open the contactor will destroy most things.
Sometimes I sits and thinks and sometimes I just sits.
