Old 12-18-2011, 12:39 PM   #30 (permalink)
drmiller100
I burn waste motor oil in my Ford 7.3 superduty. there are over 100 of us using my recipe all over the world.
Recipe:
40 gallons of used motor oil.
6 gallons Regular unleaded gas.
Mix.
Let it sit for 1 week, and most of the "soot" falls to the bottom.
Filter, leaving bottom 3 inches of barrel undisturbed.
Filter using 3 micron filters.
You can run it straight and it will start all winter just like Diesel.
Note: ATF and Hydraulic fluid requires 3 or 4 gallons gasoline per 40 gallons because it is thinner.
Also, I have used a piece fo steel brake line hooked to a 5 gallon bucket with a needle valve to drip it into a wood stove. Burns great.
Start the wood stove with a bit of kindling, throw a big log or two in once the fire is going well, then start dripping the oil on the logs.
The Following 2 Users Say Thank You to drmiller100 For This Useful Post:
AbramWagner (05-23-2015), emmaskin (12-22-2011)
