Old 12-01-2011, 01:15 PM   #21 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by Diesel_Dave View Post
Kerosene is pretty similar to diesel fuel. If guys can cut their diesel with used oil, maybe you could cut kerosene with it. I might actually use it in a heater like that. As I've already said, I value my fuel pump and injectors too much to put it in my truck.
I was actually going to tell him he already has an oil burner, just start it on kero and switch to a mix, the heater won't care, you will have more sulphur like the old high sulphur diesel however a little rock and soil can clean any sulphur out of exhaust and turn it into fertilizer.
Also If your truck was not an 07 you could add a little as top end lubricant (summer only) (1%ish or less) It would actually increase the lifespan of your motor as it did with my 82. This same concept works on cars as well, top end lube is not a bad thing for motor wear, especially on older cars, but a little goes a long way. Best to filter the stuff first though but if you take the time to filter it you might as well reuse the stuff.
The problem with new motors is that the pollution control turns high sulphur fuels into sulphuric acid which destroys your motor (not your injectors mind you) and pits the whole thing into a pile of crapola. Your injectors would still be just fine though the rest of your motor would have little compression and make a lot of noise.
Cheers
Ryan
Old 12-01-2011, 01:32 PM   #22 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
So just do half and half with kerosene and diesel or what?
I have a crummy old kerosene heater out there that's basically a glorified candle. Would the wick be able to handle the oil alright?
Old 12-01-2011, 02:28 PM   #23 (permalink)
FPO
FPO's Avatar
05GT - '05 Ford Mustang GT
90 day: 27.4 mpg (US)
Originally Posted by Cd View Post
Why We Should Recycle Used Oil
Used oil does not readily dissolve in water and is slow to degrade in the environment. One pint of oil can produce an oil slick nearly one acre in size. Used oil from a single oil change (approximately 4 quarts of oil) can ruin 1 million gallons of water...a year's supply for 50 people. – City of Chicago Used Motor Oil Recycling
A quart of motor oil can contaminate up to 250,000 gallons of drinking water! – DPW Bureau of Sanitation
Recycling just two
gallons of used
oil can generate
enough electricity
to run the average
household for
nearly 24 hours.
Recycling all the
waste oil generated
in the United States
over a single year
would save half
the annual output of
the Alaska Pipeline
Old 12-01-2011, 04:44 PM   #24 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
To be honest I don't really know. I'd look around at what the diesel cutters do. I think I remember it was more dillute than 50-50, but I'm not sure.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 12-02-2011, 01:13 PM   #25 (permalink)
rmay635703's Avatar
Wax is heavier than diesel or motor oil and burns with a wick.
The differences from heavy oils to light is the ignition temperature and the A/F ratio,
If you can figure a way of starting on kerosene and then running on a diesel/oil mix you should be fine. From what I remember diesel and motor oil don't "wick" very well (aka you would run out of fuel)
But I guess what do you have to loose? A wick and the irritation of cleaning it out?
Old 12-15-2011, 12:11 AM   #26 (permalink)
Burning WMO in a kerosene heater sounds to me like a recipe for monoxide poisoning. Those things are designed to vent their fumes indoors without a whole lot of ventilation. They really need to burn super clean.
I've found that WMO mixed with wood shavings or sawdust makes a great firestarter. It greatly reduces the amount of ashes in your stove too since you're not burning any paper.
Old 12-16-2011, 01:58 AM   #27 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
recycle waste oil I dont think its as eco as you all think. in LA most of it use to go to bunker stores (fuel for ships) they burn the cheep s--- out at sea No Regs past the 2mile
Old 12-17-2011, 11:23 AM   #28 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
Part of me is pondering on something like this:
Liquid Cooler Lineup: Intel, Corsair, MainGear Tested - HotHardware
But with longer hoses and heated by basically a glorified candle outside the car. (i don't wan't to burn motor oil inside it)
I was thinking of warming the ventilation air before the defroster heater core, so it shortens engine warm up too.
Old 12-18-2011, 09:34 AM   #29 (permalink)
EcoModding Dilatant
Volvo - '00 Volvo V70 XC AWD SE
90 day: 27.7 mpg (US)
The waste-oil heaters being discussed here have a separate combustion chamber or flu pipe. Mixing waste oil with unvented kerosene heaters that simply use a wick to heat air in the room is a very bad idea. Every contaminate in the oil, from metals to arsenic, is going to be put into the air you are breathing.
The only thing that is even remotely safe to use in those heaters is K-1 kerosene.
The Following User Says Thank You to instarx For This Useful Post:
brucey (12-22-2011)
Old 12-18-2011, 12:39 PM   #30 (permalink)
I burn waste motor oil in my Ford 7.3 superduty. there are over 100 of us using my recipe all over the world.
Recipe:
40 gallons of used motor oil.
6 gallons Regular unleaded gas.
Mix.
Let it sit for 1 week, and most of the "soot" falls to the bottom.
Filter, leaving bottom 3 inches of barrel undisturbed.
Filter using 3 micron filters.
You can run it straight and it will start all winter just like Diesel.
Note: ATF and Hydraulic fluid requires 3 or 4 gallons gasoline per 40 gallons because it is thinner.
Also, I have used a piece fo steel brake line hooked to a 5 gallon bucket with a needle valve to drip it into a wood stove. Burns great.
Start the wood stove with a bit of kindling, throw a big log or two in once the fire is going well, then start dripping the oil on the logs.
The Following 2 Users Say Thank You to drmiller100 For This Useful Post:
AbramWagner (05-23-2015), emmaskin (12-22-2011)
