Old 12-18-2011, 03:50 PM   #111 (permalink)
oldbeaver
Mercedes 89 D - '89 Mercedes 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Skoda Octavia TDI PD
90 day: 38.84 mpg (US)
1993 Mercedes 300D Turbo - '93 Mercedes Benz 300D Turbo W124
90 day: 26.19 mpg (US)
Crossie - '16 Subaru XV Crosstreak
90 day: 9.61 mpg (US)
90 day: 33.34 mpg (US)
Alternator switch
Originally Posted by drmiller100 View Post
hook a switch to the throttle. When throttle is closed, field windings are energized.
with the same switch, turn off the power to the fuel injectors.
Your first sentence sounds good to me: alternator will be ON every time the car is down a slope or going to stop.
However, it will be on always on accelerating.
The second sentence I do not understand: turn off the power to the fuel injectors with the same switch.... while coasting .... hmmm ok, that makes maximum fuel saving. I think this is already programmed so in modern diesels, I donīt know about gasoline engines.
I think yr ideas are good because they are logical and simple. Good for starting. However, I would like to have more power when climbing, and more fuel yield when traveling, turning off the alternator, when possible. Arduino can help.
Oldbeaver
Mercedes 300 D turbo 1993
