Old 12-20-2011, 02:06 AM   #14 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by ConnClark View Post
Its well proven and measurable on a dyno that insulating an exhaust pipe can improve power through reduction of back pressure. And a reduction in back pressure will translate to a real world savings in fuel. Why would you list it here?
Because the implied claims I saw for great fuel economy on the Thermo-Tec box in the Autozone seemed misleading. Unicorns often exaggerate plausible results for marketing advantage, like a horse with a horn, or that can sprout wings and fly! But maybe this thread should be moved by moderators. I'd support that.
If your going to do a grill block of any kind you will want to reduce under hood temps as much as possible.
Agreed. And so, the questions. Thanks.
PS. don't assume painting a heat shield black is going to make it work better. It may make it work worse.
I didn't. It's about appearance. Only top side is painted. Why worse?
And thanks for the link. The civic has a cover, but I would bet it could be improved.
