Old 12-20-2011, 03:26 PM   #16 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Ugh. I consulted the materials you linked. Thanks. Clearly painting my shield was a mistake as far as the emissivity of the shield goes. But IAT temps are down from when the heat shield was off. So I have to think that an aluminum heat shield painted flat black on the side opposite from heat source (exhaust manifold) is significantly better than none at all. But do you know a good layman's way to estimate the difference between my heatshield painted versus unpainted? If it is significant, I can consider removing the paint, obviously.
