Old 12-21-2011, 11:28 AM   #50 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Hello Youri,
The controller already tracks amp hour usage. It is displayed in the bottom right hand corner of RTD Explorer.
This is only for each time the controller is turned on. So if you drive to work, and use X amp hours, and then later on drive home you use y amp hours, your total between charges is x+y.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
