Old 12-21-2011, 10:59 PM   #30 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by ron View Post
every car with a standard oxygen sensor could benefit from a wide band sensor. if you have a 2 or 3 wire sensor for about 70bucks and a search DIY on how to convert to a 4 or 5 wire wide band oxygen sensor now referred to as sensor oxygen meter,the old sensor told the ecu too lean or too rich , or the bang bang effect. the newer meters are capable of (metering fuel ) well the ecu uses the info to meter fuel. should be worth about 3 to5 % so you can figure payback mileage. note an oxygen sensor fails to properly cycle at around 70,000 mi , so you might need a new one anyway. cheaper and less hassle ,only about 2 to 4 hrs max.
But do you think the DX ECU I have will be able to "read" and use the data for engine management?
