Old 12-22-2011, 03:26 PM   #20 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by drmiller100 View Post
the black yellow wire is the one we are talking about.
do NOT just ground it, ever.
if you unhook it, then start the car, the alternator will not charge.
If you then hook it up, the alternator will start charging.
If you then unhook it, with the car still running, the alternator will still charge.
You need to "ground it gently through a lightbulb" to kill the field so it quits charging.
Would a lighted switch on the dash do the job? I think it would be a bit less than 5 watts.
