Thread: Igor the Aygo
Old 12-22-2011, 05:31 PM   #59 (permalink)
Sykomor
Igor - '07 Toyota Aygo
90 day: 63.4 mpg (US)
Originally Posted by euromodder View Post
Did you compensate for the bigger diameter ?
The odometer will show 8% less distance than what you've actually done.
Tire Size Calculator - tire & wheel plus sizing
Bigger wheels are also heavier.
Wider wheels mean more drag.
Looks like that's enough to cancel out any improvements in RR if you're already correcting for the bigger diameter.
I think you are right; there is a difference but it's canceled out by weight and drag. The UltraGauge was carefully calibrated but the final answer will come at the next filling.
I put the bigger tires only in front and they are really too big. I have to be very careful at turns and bumps. I think though that 175/65-14 or even 175/70-14 would fit.
