The only Porsche I drove had the hand brake on the left side of the drivers seat tucked down so you didn't snag it getting in and out, not ideal but it worked, my commuti-car has the hand brake pull up right under the steering wheel, having it pull out of the dash like it is on pickup trucks is also an option, as I see it, the gear shift should be pretty far forward that it shouldn't be in the way of the passengers feet, if you are unsure of this try sitting in the back seat of a car that has the passenger seat removed and see how far forward your feet rest.
Do you have any photos of your progress so far?
