Thread: Igor the Aygo
Old 12-23-2011, 10:50 AM   #60 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Sykomor View Post
The UltraGauge was carefully calibrated but the final answer will come at the next filling.
Did you calibrate it against a GPS to get the distance ?
If it's carefully calibrated against the car's odometer it means the Ultragauge will also be off with bigger tires .
I put the bigger tires only in front and they are really too big.
There's no point in going so far that the tires don't physically fit anymore
I'd stick with rather narrow tires - maybe 165 instead of 155 but not much wider.
