Originally Posted by daverods
If you are reading this you are most likely a Toyota owner or have owned one in the past. I have grown up with Toyotas my entire life, mainly because my dad was a fully certified Toyota mechanic. We all know that 90% of Toyotas older cars are virtually indestructible, unless they fall victim of being hit by a large truck.
The BS is getting deep here...
Toyota makes decent enough cars, but there's no need to deify them (well, maybe the GT-86/FR-S/BRZ. Damn, I lust over that thing!). I've done enogh major engine repairs or replacements on Toyotas to know that they are no where near indestructible.
- High cold idle is probably not a big concern by itself. This is a small percentage of your driving time, unless you do a lot of little trips.
- Not sure of your car's specs, but this sounds high.
- Uh... yeah, fix the leak. That is likely the cause of the high idle and could cause unusual driveability problems, maybe even low fuel economy.
- Yes, check that. Significant alignment issues will also lead to unusual wear patterns on the tires.
- yes, this is hurting you a little. Lower just the rear and aerodynamic drag increases.
I'd fix the vacuum leak first and get an alignment and see what it does. If it's still low, look for other maintenance problems and adjust driving habits.
