SG-e: loose OBDII plug
I received a ScanGauge-e for Christmas, which I am promising myself I will use safely (and not stare at it instead of the road).
The OBDII plug seems to be loose. It has popped out a few times already when I brush against the loose wire (I plan to route the wire neatly later). How much play should these things have?
EcoDriving: Turning more fuel into usable forward motion.
