Old 12-27-2011, 12:58 PM   #2 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 50.97 mpg (US)
Originally Posted by vacationtime247 View Post
in this pic, what should the angle be from the roof line to the end of the kammback? Is this something that only tuff testing will determine? Will the added area cause a noticable push with crosswinds? What % increase in general will this add?
15º is usually considered "safe". But it depends on lots of factors. Vekke did an adjustable one on his diesel VW Lupo and tuft testing revealed he could go lower than his first attempt. I only see a profile shot of your Kammback. Are you going to taper the sides in as well? Are the corners between the sides and top gently rounded? How smooth is the transition from roof to Kammback?
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
