Originally Posted by fusion210
Although it's argued that the biggest gains are at the rear, I think some of the lowest hanging fruit is sealing off any useless gaps in the front end and constricting airflow to the radiator.
This is an area of very high pressure air trying to force its way into every drag producing opening or gap.
Originally Posted by KamperBob
Between experts here and what I've read so far from Hucho and Hoerner there is interaction between front and rear. If (IF!) a given vehicle already has fully attached flow, THEN it seems that wake reduction provides more bang for the buck. If the front, top, sides and/or bottom are a mess producing detachment than wake reduction offers limited return.
I have been working from front to back on my vehicle, figuring I needed attached flow for the mods at the back to be effective.
Perfect onset flow and attachment also tend to amplify base drag. So without good rear treatment, forebody work alone is limited. Everything matters.
Interesting, I don't have Hucho so I hadn't heard this before. So now that my front end and underside is smooth, I really need to get moving on my hitch mounted boattail/cargo carrier.
![EEK!](/forum/images/smilies/eek.gif)
